87FJ60
Dizzy is lose. Still wont pull out.
Stuck.
Pry bars have entered the chat.
Still stuck.
Wild.
rotate with up pressure on bar, should "pop" up, the oring is most likely hanging it up
Alright. Still stuck. I feel like I’m missing something.
a crows foot or heal bar underneath won't pop it out of there?
it is odd that it will raise up slightly but not come all the way out
there is a gear on the shaft engaging the cam shaft and a flat on the bottom which engages the oil pump, along with the o ring and slip fit of the housing
unless the housing is broke and separated in the block above the o ring??
Victory!!
RIP OEM Dizzy ☠️
Took an absolute beating. Used a long pry bar to hammer at it from underneath.
Non-US dizzy stabbed. Timing set.
Thanks to @4Cruisers for the points to electronic dizzy conversion!
Still need to finalize my desmog and fine tune.
so the housing was broke above the oring.
I've seen that once before.
Not quite the issue though. The housing where the lock down bolt goes (missing now) was broke off during my fight to get the dizzy out.
