I have an 86 4Runner that I'm installing an engine harness in, what I've noticed is that the new harness does NOT have the connector for the temp sensor located on the top of the thermostat housing. My question is what is the sensor for, I know the temp gauge sensor is located on the intake manifold water passageways, I seem to remember something about that sensor being used for towing and or 4WD so if the engine starts to run hot the ECU would limit power. As most of you know these harness are becoming harder and more expensive to find, the harness that I'm installed is in real good condition, all I've had to do is replace the injector plugs.
you are right about the DLX having the expanded cluster. My 1991 pkckup is a regular cab DLX and has the expanded cluster.
