Vaseline. ...... If lubricates the track and softens the rubber. It has worked well on my '87.
Maybe this can help someone out..if you remove the top, and replace it, there is a switch that is engaged by putting one of the bolts back ( covered many times )..
However, make sure to use the right bolt (longer) as the shorter bolts will not reach the plunger and engage the switch. EASY FIX. Or just take driver rear inside panel off , unscrew the switch, push plunger by hand to test. Hope it helps anyone...
(That’s the official welcome emoji). Welcome to ‘Mud!(That’s the official welcome emoji).
Do you have a link to where this was “covered many times”? I’d like to put my hard top back on, but my glass stopped working just before I installed my Softopper, and I want to get it working before I make the switch.
