- Joined
- Sep 3, 2014
- Threads
- 1
- Messages
- 3
Hey ya'll,
My partner ZombieResponseUnit is currently unavailable via internet, so he suggested I post up on here. We've been trying to diagnose this issue for a while now. First, some remedies we've tried: a loose mounting bracket rubbed a hole in the radiator, so it was soldered. While the radiator was out, it was flushed multiple times, and the cooling system was flushed at least 15x. When it overheats, I find it's still losing water somewhere. Zombie thinks the radiator isn't pulling from the reservoir tank - possible pinhole in hose? I'm having to pull over every 30 minutes to re-fill the radiator. Higher speeds and grueling VA heat definitely make it worse. He drove it 4.5 hours in cooler temps with no issue, and I did the same this winter. I'm pulling a lot of hills in 4th on windy roads and not able to put it in 5th. If this isn't resolved soon, we're swapping the motor for a diesel - isuzu c223 or nissan sd22 and/or replacing the radiator. I love this truck and can't give up on her, so all suggestions are appreciated. Sidenote: OEM brass radiator, all factory engine, except radiator hoses, brushes and alternator.
