81 pickup engine / idle issues
Hey I have an 81 pickup that according to the emmissions tests is running on basically straight gasoline. Does anyone have any suggestions on how to fix this. I have tried fine tuning the carb but the engine doesn't seem to respond. Also my Truck won't idle right, which i think will be solved if i can fix the carb issue. Any help is good
You will be better served in the truck forum. A moderator will move it for you.
Dang Romer was fast.
Question. Is this a California truck? The reason I ask is the CA trucks have an OX sensor (at least my 82 did). Most folks with CA carb'd trucks don't know about the Ox sensor. A failed sensor will cause the truck to run rich. BTDT.
The second cause of high HC is a failed smog pump.
Third up, the cat.
