- Thread starter
- #21
Good story with pics, re_guderian, thanks for sharing!
I'll give you an example... It's not rock-crawling at all. Eight years ago I went by myself on a trek to drive from the AZ/Mexico border to the AZ/UT border on 4WD trails and dirt roads.
enough to make point about safety tradeoffs.take out the 2nd/3rd row to save weight. front passenger seat too. I did that when my truck was stock, definitely was faster.
Think they're just for overland? Think again.
I hear you Farinvail, it makes sense.
Lets just say it where possible to shave 300lbs off your weight. Would your ride improve much? Or is it the suspension mods that cause the ride performance issues?
This is the thread that started my thread:
https://forum.ih8mud.com/100-series...ension-set-up-what-does-your-truck-weigh.html
I think I am going to try to find a way to put 1,000 more pounds in the truck just to see if i can do it.I come from a backcountry hiking and camping background where the lighter your gear, the happier you'd be on your trip. The credo was, "light is right".
Doesn't this apply to off road vehicles as well. Lets shave down some weight:
RTT 125lbs (setup time 1 min)
- replace with backpacking tent and pads 10lbs (setup 5 min)
Engel Fridge 52 lbs
- drink Scotch instead of beer (what else do we need to keep cold? Milk?) Ok, Cooler and ice if really needed 20lbs
Dual Battery Setup 28 lbs for the extra battery
-replacement take it out 0lbs
Rear Drawer systems 170lbs
- replacement Rubbermaid action packer bins or equivalent 10lbs
Rear bumper with swing outs 200 lbs
- put the tire on the roof 0 lbs
Front bumper 150 lbs
- use stock bumper,let it get scratched up, I know lousy approach angles. 0 lbs
Winch 90 lbs
- remove it, use tow rope and recovery gear 10 lbs
Sliders 90 lbs
- remove them 0 lbs
Roof top rack ARB 120 lbs
- instead use Yakima road warrior rack with tire mount 35lbs
Pelican Cases 2 @ 35 each for 70 lbs
Total for these options 1095 lbs
- replacement items weight 95 lbs
I just shaved 1000 lbs (some items are ballpark) without touching the suspension or tires.
So you loose on departure and approach angles, but how often do you actually hit things or bushwack with the steel bumper? Seems like most of the hundy crew is not hitting Rubicon style trails, here in the US anyway. This is an overland king not a rock crawler.
My replacement gear is not quite as hardcore or sturdy.
However, for 90% of the trails most people hit do you think this weight savings would actually improve off-road behavior? Not to mention, I just saved about 15-20k in parts and a whole bunch of gas.
What do you think?
That is certainly not the kind of terrain I ever imagined a hundy on, very cool.
The one area we want improvement is washboard roads, we drive on hundreds of miles a year of really bad washboard and we want to fly, not poke along at 20MPH.
In the desert there is rarely a tree to winch from. I bought a pul-pal for that reason. I never want to have to dig a hole to to bury a spare tire. Lucky you had a tree! probably the only one within a hundred yards.I'll give you an example... It's not rock-crawling at all. Eight years ago I went by myself on a trek to drive from the AZ/Mexico border to the AZ/UT border on 4WD trails and dirt roads. No rock-crawling whatsoever. In hindsight, going solo was stupid, but I follow the old Boy Scout motto of "Be Prepared" pretty well. I had 2 spare tires, gas, water, food for a month, tools, shovels, high lift jack, 3' iron pipeconfused: - but best tool I own), and most of all a mountain bike for back up transpo... In one week I saw less than a half-dozen other cars.
I ended up driving at night on the Apache San-Carlos reservation east of Young, AZ. Total and complete B.F.E... I was going about 15 MPH when I took my eyes off of an innocent dirt road for just a flash, and ran my driver's side tires off the road indicated in picture 1. Instantly flatted both tires and bent the front rim. No lockers, trailer hitch buried and both DS tires spinning. That was 9PM. By daylight, I had managed to get myself back on the road. I had to use the indicated tree as an anchor point. If you're wondering if that's within the 100 ft. of winch cable I had, it isn't. I had to shackle the cable to a 30 ft, 30,000 lb strap, which barely reached the 6' tree saver around the tree. If you're wondering if my carb float floated at the angle I was at enough to keep my truck idling to charge the battery while I winched, it didn't. But the highlift with bumper attachment helped. I also used the highlift and the 3' iron pipe to un-invert my shackle and get my leaf spring back to where it would "kind-of" spring. It's all about getting home... Without extra "weight" I would have waited DAYS for someone to come by and help, maybe even longer. Because I had a steel front bumper with a winch, and was dragging a trailer full of crap, I was able to spend a glorious AZ night getting unstuck. That was pretty much the end of my trip (1/2 way), but I made it home under my own power.
