I come from a backcountry hiking and camping background where the lighter your gear, the happier you'd be on your trip. The credo was, "light is right".
Doesn't this apply to off road vehicles as well. Lets shave down some weight:
RTT 125lbs (setup time 1 min)
- replace with backpacking tent and pads 10lbs (setup 5 min)
Engel Fridge 52 lbs
- drink Scotch instead of beer (what else do we need to keep cold? Milk?) Ok, Cooler and ice if really needed 20lbs
Dual Battery Setup 28 lbs for the extra battery
-replacement take it out 0lbs
Rear Drawer systems 170lbs
- replacement Rubbermaid action packer bins or equivalent 10lbs
Rear bumper with swing outs 200 lbs
- put the tire on the roof 0 lbs
Front bumper 150 lbs
- use stock bumper,let it get scratched up, I know lousy approach angles. 0 lbs
Winch 90 lbs
- remove it, use tow rope and recovery gear 10 lbs
Sliders 90 lbs
- remove them 0 lbs
Roof top rack ARB 120 lbs
- instead use Yakima road warrior rack with tire mount 35lbs
Pelican Cases 2 @ 35 each for 70 lbs
Total for these options 1095 lbs
- replacement items weight 95 lbs
I just shaved 1000 lbs (some items are ballpark) without touching the suspension or tires.
So you loose on departure and approach angles, but how often do you actually hit things or bushwack with the steel bumper? Seems like most of the hundy crew is not hitting Rubicon style trails, here in the US anyway. This is an overland king not a rock crawler.
My replacement gear is not quite as hardcore or sturdy.
However, for 90% of the trails most people hit do you think this weight savings would actually improve off-road behavior? Not to mention, I just saved about 15-20k in parts and a whole bunch of gas.
What do you think?
Engel Fridge 52 lbs
Winch 90 lbs
Sliders 90 lbs
- remove them 0 lbs
What do you think?
