80 vs 100 series at altitude
See you in the right lane soon! 3k rpm in 2nd going 40mph up a 10% grade at altitude. Slow cruising is a lifestyle, I ride a motorcycle if I want to go fast.
As long as you keep in mind:
91-92 models with the 3FE motor is 155 HP and 220 torque
93-97 models with the 1FZ-FE motor is 212 HP and 275 torque
Early 100 series models is 235 HP and 320 torque and over time up to 265 HP
By changing gears and tire sizes can have a big influence on performance
This is a great comparison. I will add that the 200 is 381hp and 401ft-lb.
The 80 can be slow up hills (some areas from Phoenix to Flagstaff keep me at no more than 65) and the 100 helps a bit (70-75 on that same hills) but the 200 seems to go with out effort ( easily accelerating up to 85 on that same hills)
In short, I have had all 3. 80 is my favorite and a bit slow (that ok for me), but the 200 is so easy to drive. I would recommend skipping the 100 all together.
Sounds like for a lightly modded vehicle (say 33” tires and a 2” lift) there isn’t much difference off road but there is more mod headroom with the 80 series?
212 vs 235 isn’t exactly a transformative difference tbh. What years did the LC100 get the power bumps?
2006/2007
My 1993 FZJ80 makes 404hp and 530ft-lbs at the crank😎....
