80 series diff lock wiring
This has all of the connectors in the harness listed.
You can swap in locker wiring harness... Sounds like the way to go if you can't do the wiring
Hi
Can someone give me part numbers on connector housings and pins for diff lock sensor? I would need numbers for the connector on body side wire loom.
What model year did you get the diff lockers from ? Do you still have the connectors on the doner harness ? How many wires are in the harness, and what colors ?
In that case just buy the low range off road harness.. it's everything you need
I think this may be what you're looking for.
Just for guys using the search function, here are the part numbers listed out:
Connector: 90980-10576
2x repair pig tails: 82998-12270
