80 Series - 6BT + NV4500 + HF2AV Swap
Draper, UT
I have been documenting my build and Cummins 6BT swap in the 80 series tech section. For those of you that want to see another swap, here is the link to my thread.
I am currently very close to being able to fire her up for the 1st time.
Dirty Koala - Cummins 6BT + NV4500 + HF2AV Swap
Presently trying to bleed the air out of the fuel lines/ P-pump...quite a process.
Yup it's not fun even after fuel filter change. Since there is no bleed screw, only plunger pump, I result to the pedal to the floor method while starting hoping to get it running before battery juice is depleted.
Yeah, its a PIA. I have a friend stopping over this evening to lend a hand...hopefully we get it bled, fired up and idle adjusted to about 800.
another shot of doors , bought these before they came out with the best top compadible ones ( damm it ) i think i can just drill the holes in mine tho , got the door tops just need to get the soft top , dont think i will ever put hard top on again and a soft top will get me a month or more of driving it on front and back end of summer
Everyday I tell myself to hold off on ordering the tailgate panel. Yours looks so good.
