80 series 1fz not starting
Brisbane Australia
Hi all. I am having issues with my 80 not starting. It cranks but doesn’t fire. So far I have done the following.
New leads and plugs
MAF is opening
I have fuel
Timing at 3tdc
TPS is in spec
Fusible link changes
No fault codes are coming up
I’m running out of options
Thanks
New leads and plugs
MAF is opening
I have fuel
Timing at 3tdc
TPS is in spec
Thanks
What year is it? Did you check the fuses?
You say ‘I have fuel’.
Does that mean you know you have fuel in your tank? Or does it mean you know you have fuel getting to the engine?
Check EFI fuse and ICM
have you checked if you have spark?
SPARK TEST
CHECK THAT SPARK OCCURS
(a) Disconnect the high-tension cords (from the ignition
coil) from the distributor cap.
(b) Hold the end approx. 12.5 mm (0.50 in.) from the body
ground.
(c) Check if spark occurs while engine is being cranked.
HINT: To prevent gasoline from being injected from
injectors during this test, crank the engine for no more
than 1 - 2 seconds at a time.
