www.gamiviti.com/roof-channel-towersWhich Gamiviti mounts?
44” minus 1mm. So, 1116mm. They will cut it to that.I measured my needs to be right around 44" as well, like OP stated (1998 here). I'm thinking 44" and sanding down to fit makes a lot of sense. Anyone have more input before I pull the trigger?
I'm thinking about building a carrier box out of wood then weather treating it to store crap on top, has anyone every just rest the box on top of the roof itself, not the crossbars, then use the rack's sidebars to secure it? i'm trying to keep this as low profile as possible to cut down wind and not disturb MPG too much.
I don't see why not. The roof has stick on protectors. I might get some robust foam to lay down to give the box some bite so it can be cinched down tight.
I’m gonna be honest with ya. That sounds like a terrible idea. From aesthetics to safety.Yeah i dont like sticking a box on top of the cross bars because it's just too high up and the wind passing underneath will act as a sail. I'm going to build my own low profile box that sits 6" above the roof, the sides will be secured to the rack and the bottom will just rest ontop of the roof itself. Won't have anything heavy in there, probably just for tow straps, cooking utensils, and accessories or what not.
Put series 10 on my 2005 lx 470. I don’t plan putting much up top so I opted the series 10 and did just standard bracket brackets. Length was 44 1/4”. Purchased from tnutz. I’m also happy to report that I only needed to remove the rear roof rack caps and slide the oem cross bars off. I like the flexibility of the slots. No noise yet.
44 1/4”
Snug fit? Just right?
