79fj40 on 80 chassis!
Is a 22re engine with dual cases. Linked front and rear with 39 stickies.
Basically 1994 pickup parts.
Front axle is fj40 rear is 9 inch with 5:29 gears. Welded front spool in back.
My last 40 was 22r powered w/a 4:1 case and 60/14 bolt. Traded it 5 years ago and still kick myself for doing so!!!!
On the same 40, I used a 60 column and mini truck shaft so it had tilt, blinkers, horn etc in the column. I just had to rework the mount brackets at the floor and the where it bolted to the dash. Worked out pretty well.
@halffzj80
The rear frame structure is going in. Friend of mine cut and bent wheel well covers on a cnc , 1/16 metal. I think they’re 4 inchLonger than stock
Youre giving @JackA a run for most efficient re-model! Progress looks great and product looks great! Thanks for sharing.
Moving fuel filler door to driver side. I’m reusing fj80 fuel tank and filler neck. Had to make the tank smaller because I moved the engine back and now there’s less room where the original tank was located.
Moved the exhaust to run inside the frame and removed catalytic converters. Used stock muffler and removed resonator from the rear.
Removed rear O2 sensor. Will be running only front O2 sensor for air fuel mixture.
With body back on and all body mounts attached I moved on to the brake system before installing front fenders. Installing stock master cylinder and removed Abs pump. Also removed rear load sensing valve.
You’re moving!
Battery box. Lots of guys delete the blower motor and install the battery there. I’m keeping the blower so I can reuse original heater core box
Actually I’ve been driving the 40 for couple months now. So the time line is not accurate. Just been posting everyday to show the progress over 5 years period.
This makes waaaay more sense. Not doubting your abilities, but i was like this guy has his sh1t together!!!
