78fj45 Leaking master cyl
Prince George B.C.
Reseal or replace? Reman or new? From who or where?
Thanx
Are we talking about an original 27 YEAR OLD master cylinder?
Funny-I was thinking the same thing. Get a new OEM master cylinder and be happy for another 27 years! $$ spent on brakes is a good investment.
get a new OEM and don't worry about it for a very long time.
I have used some aftermarket brake and clutch master with good luck(so far) but prefer OEM
Now I am making an assumption that the 45 uses the same MC as the 40.
But I got a remanufactured AISAN Iron MC from Oreilly for 33 bucks with a 25 dollar core for my 78 FJ40.
Napa sells the Power Booster for 100 and something if you want to replace that while you are at it.
The 1978 FJ45 pickup uses a 1-1/8" bore master cylinder for the 4 wheel drum brake system that they have.
The 1978 FJ40 Land Cruiser uses a 7/8" bore master cylinder for the disc front, drum rear set up that they have.
These vehicles DO NOT use the same master cylinder.
From Toyota, the FJ-45 pickup master cylinder is far more than 100.00us.
Good luck!
-Steve
Well there you go.
If you use the parts lookup thing on Napa Online they don't distinguish between land cruiser models for 78. I have to assume that Oreilly, Autozone, Checker, or whatever don't either.
I have brand new masters but they're a lot more then $100 USD
they're probably $170ish USD gave or take a few bucks on the exchange
1 1/8 bore for FJ45's with the larger brakes
