78 I\E manifold question
Old Fort N C
Sub thread to the Bat Cruiser build thread.
I sand blasted these two, then resembleD them with the same gasket. Obviously they are not aligned correctly. Am I missing a gasket? Looks like the bolt holes would line up with another gasket.
I have a machinest who will flatten the face for the head and end bore the bolt holes, but need it better than this for him to start.
is there a crack in the intake? looks like it
what is between the intake and exhaust? going by memory, there should be 2 exhaust gasket material gaskets and the steel deflector piece.
it should be gasket-deflector-gasket
it looks like the intake needs to be separated/spaced further from the exhaust
is the exhaust flapper functional?
that exhaust manifold looks more like a 75-76, I thought by 78 all the manifolds were 3 piece.
I would say you need to loosen the bolts holding the intake to the exhaust and then line up the mounting holes to the head. Once that is done then re-tighten the bolts holding the intake to the exhaust. You should get a better match.
1. That intake manifold is definitely cracked.
2.it is NOT an 852F; that manifold was not used after 1976. The EGR on the ‘79 and newer fits to the intake; that one is designed to take EGR at the carb.
3. IF the intake manifold was repaired from the underside, then it’s worth separating to use the dual gasket and heat shield. It’s also worth upgrading to the newer 3piece exhaust which rarely has bolt hole alignment issues to begin with. (Alert Winston Churchill, I ended a sentence with a preposition :p)
Best
Mark
@65swb45 , I did not catch the crack, you can see where it has been repaired where the little tab bolts on.
I will contact you after Christmas to talk about replacing the exhaust side, and a couple other things.
I bought this as a parts truck, and thought the engine was original to the 78 body, but the block # shows it to be 85ish fj60 I think. Pic of engine in the Bat Cruiser thread.
Thanks for your input!
the crack Mark and I are pointing out is below the carb.
it is clearly visible in the last pic, looking straight down into the intake.
Great catch by both of you! I looked at again today and it was so obvious, I am embarrassed I missed it.
@65swb45 , I am going to a friend whom has a few parts, is there a number by which to ID the proper pair for the 95 2f?
I will call you next week about t case bushings on ( I think ) the input shaft.
Did anyone mention the old aluminum repair on the right side just below the casting number? Definitely not a premium manifold
