Hello friends, great forum here thank you for all the wisdom and info from the past contributors.
I don't think my question is new, but more of a those of you were here what did you do. I can tend to really focus on things that drive me batty. this is one.
THE DEAL: I am in the middle of nut and bolt (literally) resto. I just rebuilt top and bottom the original 78 2f (domed piston) engine. New valves, new everything. Turned crank, turned cam. $1100 machine shop bill. I have a weber 38, MSD coil, gallery distributor, header, ect..... Perfect setup.
But I knew that once I got it going I would love to have the 3fe or diesel conversion. My motive isn't really an all stock resto, but an all toyota driver that is a really nice mostly stock rig. Im not in my aggressive 4x4 days anymore, this would be a 2-3 time a week driver and then some utility on some land. The EFI is def a comfort choice for me, I know the weber is good, but I'm tired of messing with carbs. Im a tinkerer and it always gets worse.
Yesterday I purchased a complete 3fe (needs a coil + igniter; hit me up if you have one) that has a cracked block from a water freeze. It came with a good block, but feels like would need to be machined.
THE QUESTION: For those of you who have been here what do you think & WHY. I have read endless threads on here. I am trying to determine my least expensive vs best case scenario and I simply do not know what the market value on this stuff is. Option #1) A 2fe (stroker) I would need to tear down my new motor and replace the domed pistons (which I didn't know yesterday). Is the 2fe that much better than the 3fe? I could part out some stuff like the 2f head, carb, dust, 3fe blocks. Option #2) Part out my Original 2f (sad) and sell the short block complete. How much is an all new rebuilt 2 worth? Then rebuild the 3fe. It already has the power steering pump and AC compressor which I will need.
I would love to hear your thoughts.
-jb
-jb
