- Joined
- Jul 26, 2010
- Threads
- 4
- Messages
- 44
Check this video out for the vacuum leak. I used this method to find the leak on my ranger and it worked well.
Very nice photos- Thanks!See if some of these pics help. I don't think that egr pipe is part of the vacuum system. It doesn'tView attachment 1345515 View attachment 1345516 View attachment 1345518 View attachment 1345519 View attachment 1345527 look stock either so you may have an issue on the visual inspection.
Can you read the part number at the top of your VSV. I can't quite make it out in the photo. According to the fiche, the part number should be 17650-61040 for a Cal. Spec. 8/76-9/77 VSV.
That agrees with the photo posted by iptman.
Yes that's an original distr
I suppose I could at a later time. I'm pretty confident all the parts are there. I recently obtained the two hard to find VCVs from a fellow Mud member. It does have a CARB approved header, made by Downey and has the sticker with EO# under the hood. I do need new rubber tubes leading from the ABV (smog pump and air rail). Any ideas on replacement parts?You should post up some pics s of your engine bay and let folks comment on what's there and what's not.
Here's a link to the '77 emission manual Page 223 Land Cruiser Toyota Maintenance, Emmissions & Front Axle Manuals
You'll need the '77 PM sent.Not to hijack the thread but I was wondering. If I own a 5/1977 FJ40 what Toyota Emissions Control Manual do I need? The 1976 or 1977 manual? I believe the emissions configuration changed around 8/1977.
Jeff
Thanks for the photo. Helps to confirm the part #.
Maybe so, but I only know from my serious frustration and ultimate satisfaction. And, I don't remember about the screws but I did have about a million screws on the shelf at the time; metric and the other ones. They are all in storage at this moment. Any way, passed smog runs good.Do not remove the carb butterfly shafts. The butterfly screws are staked and you have to grind off the end to get the screw out and you have to get new screws. You can see if there is too much play without removing the butterfly valves.
My 9/77 only has retard, no advance.Yes that's an original distributor. Unique to the Cali 40s, it apparently has both vacuum advance and retard.
Somebody stole the valuable vac advance '77 dissy and replaced it with a vac retarded 75-76 unit.My 9/77 only has retard, no advance.
