Would appreciate any suggestions / opinions on what I should do here.
Background: 1976 model that I recently bought (my first!) and I just (apparently) ignored the suspension
because it looks like a mess to me now, but maybe i'm over-reacting. PO used it as a rock-crawler and had done a lot of typical mods including shackle reversal (looks like a BTB kit), rear scissor shackles, but looks like he also altered the spring attachment points. It has a nice stance to it, but too extreme for my intended use. (weekend fun driver, light off-roading ie. taking the family into woods for primitive camping). I understand it worked well for the PO for it's intended use, so I'm not bashing him. If I was to big a rock crawler I might have done much the same. My fault for not taking one of y'all with me to inspect it.
It failed the state safety inspection because of worn bushings. (It has poly bushings on it now, but they are in BAD shape.) So I order new bushings and start to look closely at the set up and several (all?) attachment points look bent. On the test drive, I didn't notice any wonder on the road, but last time I drove it was hard to go in a straight line and seemed to have a mind of it's own. Frankly, it was a bit scary.
So now thinking of how to move forward. Options:
1. Just replace bushings and see how it handles (not sure I'll be able to get new bushing on all of the pins - you'll see why below)
2. #1 plus replace any bent shackles (one could argue all of them probably)
3. #2 plus replace BTB bent shackles (you'll see what I mean below)
4. Scrap all existing shackles, springs, u-bolts, etc. and get all new aftermarket lift kit to replace. I had planned to eventually do an OEM 2.5 lift anyway. (Not sure I can use an aftermarket kit because of POs custom work on spring points)
5. Go whole hog and rip out everything PO did - return to OME suspension attachments points and then go with OME 2.5" lift kit to replace everything with.
I've got the funds to buy the OME kit, but thought I would just replace bushings until I crawled under it today. I am strongly leaning towards #4 or #5 above to just have it done right. Not sure if #4 is even possible and Not sure how much #5 will cost to have a competent welding shop take off what is now there and weld in OEM attachment components for the springs.
Any and all thoughts appreciated.
I didn't realize the fj60 and the late model fj40 used the same hangers. Sounds like a good plan. Thanks again everyone.
