‘75 Fj40 Ambulance Door Missing Parts Quiz
Oahu, HI
I am in need of a little help identifying/naming a few Ambulance door pieces that the PO felt weren’t needed. Hoping there are some Fj40 experts out there that knows these pieces of door hardware I need. And of course, any leads on where to find/buy some of these parts would be greatly appreciated.
Here is what I’m looking to identify:
1. This is on the top of the DS door. I’m assuming this is a retractable latch similar to the bottom one?
2. Center of above door support. Maybe a stopper for my missing top latch part?
3. Directly below PS Ambulance door handle.
4. Inside of DS door. Looks like something used to be where spacer washers are now.
And the gap where oem blue paint is seen on inside door handle.
Any common names they go by would help me a lot for posting the correct part in the wanted classified section. Or if you have a photo of yours, I could always circle it and iquire about it.
Thanks a lot for any help you can provide in IDing these!!
3. That little cover plate pivots out of the way so you can get your key in the lock.
I'll try to snap a few photos of the rear door on my '76 here in a few minutes (flash definitely required). More answers forthcoming.
Thanks, I just pryed it open. Was rusted shut but there certainly is a keyhole there! Unfortunately, none of the keys that came with it fit.
Last I knew, ambulance door locks and keys were still a dealer item. They were sold as a set (lock and 2 keys) for cheap.
Yes, you are correct. Looks to be about $20 for the set! Thanks, I will be ordering a set.
THIS SOR LINK takes you to a similar diagram, but the components are interactive... e.g. click a component number and see the name, availability and price.
But, as someone mentioned, @65swb45 can most likely hook you up with good, used parts.
You’ll need to call Mark... probably 2 tin cans and a long string :D... at
Thanks for all the help identifying those parts I need. @liko got me set up with the parts I was missing. Big Mahalos out to him on the Big Island!!!
I had one more question, can someone tell me how the inside DS Ambulance door handle stays on? Looks like some kind of pin keeps it in place, but mine doesn’t have anything to hold it on, so it just slides right off. Looks like maybe a small nail might work if I can’t find one that fits. Anyone have a photo of what it looks like? Thanks!
