Hello Gordobe,I have 2 brackets if you are still looking
Gordobe,My photo doesn't show the pins because they are gone.
Which are you speaking of...
or....
The bottom spring, arm, clip are for the door lock. With the window up, the gate won't open. The window must be down. Some guys just wire it out of the way and run it. The top picture are the parts to open the gate with you pull the handle (must need).
Thanks for the tip scrapdaddy, I was able to turn over and find top dead centerTim,
remove your spark plugs to release compression before trying to turn over the motor by hand. I've used a large screwdriver on the flywheel gear and walk it around to where you need it.
UpdateThanks for the tip scrapdaddy, I was able to turn over and find top dead center. Now i don't get any spark
. I've double checked my work when I put on the new condensor, rotor cap and point. The only thing not replaced in the chain was the capacitor, not driving the pig for a couple weeks wearing on me. She wants to be driven!
- New Dizzy Cap
- New Wires
- New Plugs
- New Rotor Cap
- New condensor
- New Point
or find the tool that goes in the front that would move the pully
