71 FJ40 Build
Cruiserdrew
On the way there
Sacramento, CA
Since everyone seems to have a build thread, I thought I'd start one, and update as it goes along. The chassis made it outside today for the first time, so I'll start with those pics, then go back and start with axles and go from there.
The basic plan is that my 76 is donating most of it's parts to the new build-There is a quick pic of that in the background. of one of the frame shots. It will donate the 2F, SM420, 3spped case, plus the entire body.
The rear springs are FJ62 rears, and the fronts are stock 40 springs with an extra long leaf also from another FJ40 spring pack.
The axles are both FJ62 axles-the front cut and turned by Luke Porter at 4x4 Labs.
The frame is a 71-rust free, that I got from Orange 45 last summer. I've welded on powersteering, outboarded the front suspension but still have lots to do. Here are a few pics..,
Some axle shots
The rear axle was a group effort-Baldredhead gave the housing to me months ago. I wasn't sure what to do with it at first, but I decided to use it in the build. The backing plates and brake stuff I got from 3Puppies, and Green FOx. I rebuilt with new Toyota cylinders (suprisingly inexpensive!). The old bearings were probably good, but I pulled them out and installed new ones, plus Toyota seals of course. 3Puppies sent the old drums as well-they had plenty of meat and got remachined at the local tire place.
The inner axles are Poly Performance Chrome-Moly shafts. I ran those last year in the 76 40, so I reused the short side, and had on hand the 60 series long side from the Poly order last year. All new Toyota wheel studs and dust guards.
The differential is out of my 76-It had already 4.56 gears and an ARB, so I had River CIty Differentials go back through, reseal the ARBs and use a solid pinion spacer.
why not go disks if you got it all strip down? just wondering
More rear axle shots
Some random shots of the axle going together.
C-Clip!
I should add-the buttons on the Poly rear axle shafts are a little thicker than on most stock axles and required the thinnest c-clips available-using the ARB spacer block.
Not really interested in disks, plus the ebrake issues might be a pain with disks. I had all the parts, so it was a painless decision. I'll have 2 e-brakes-on the wheels and at the t-case. This axle may go under my FJ60 in a few years, so I wanted to keep it all in the family.
Some front axle shots--
I used the Longfield 30 spline set-it is so pretty, it seems a shame to hide it for years inside an axle housing!
Also-new Toyota studs in the knuckle housings-I set them in with the impact on it's lowest setting then torqued to 30 ft/lbs
More front axle-I know everyone has seen this before
Is this 2/3 full?:D
The differential has an ARB with the seals and o-rings just updated. Also a solid spacer was used for the pinion bearing preload. When Warden's set it up back in the day, they used a crush sleeve, so since it was open, it was time to do it optimally.
Last front axle shots.
I just reused the existing hubs and rotors since they were new 2 years ago and have a bunch of trips, but very few actual miles on them. I did clean and re-pack the bearings, though.
Looking at the pics, I realize the backing plates were still muddy from the last trip-I still need to clean those!
There is a good look at the 4x4 labs high steer arm in the middle picture.
Looks good man. I was just at that exact stage on my 71 3 weeks ago. Same set up but went discs in the back. I also went with arp studs on the knuckle and hubs. We'll see if they were worth the extra coin or not one day. Keep it up, and keep those great pictures coming. Subscribing to this thread now.:cheers:
Jeremy
Looks good Drew, I can't wait to get mine back to being a roller. Did the 60/62 spring hangers work for you? Let me know when you need muscle power moving the tub over.
where'd you get the studs? have a part number?
you guys thinking eldorado calipers in the rear? anybody have a thread link showing how to pull of an e-brake in that setup? pm me please, no need for a hijack.
i like that flip you have on the front u bolts. is that a manafre kit?
I ended up not using the hangers yet. I found a combination of bushings and pins that allowed me to use the standard rear hanger. Every other hanger is new and from Ruffstuff.
Notice it's spring OVER, so with the springs on top of the axle the only thing below is the u-bolts. The right side spring plate and inner bolt is custom stuff from Luke Porter.
The studs are an upgraded OEM part from Toyota. I got them from Cruiserdan. I thought about the ARP studs as well. but Luke at 4x4 reccomended the Toyota studs specifically. If I break them, I'm going to the ARPs no question.
nice work dr. drew, keep it up!!!:bounce:
as to the disc brake question, i'm 100% with you. why run discs?! i don't know a single person who's gotten the eldo calipers to work properly. however, every 60 rear drum setup i've run across works great and the e-brake works flawless as well. good choice!:cheers:
Another vote against Eldorado ebrake setup.. It sucks and does not work. Forget having a parking brake.
Very nice work. Looking forward to the progress.
Sweet build
I wish I had your front axle, maybe I'll ask Santa :D
How 'bout some pics of the body, what color?
What are ya using to coat the frame, axles, etc.?
Love those tires;)
This is a build I'm gonna follow for sure.
Keep it up
-my64fj40
Looks good Drew, Glad you can use the rear backing plate. I second the vote for rear 60 drums because you can adjust them the way you want and the second parking brake rocks.
