Are the regulators difficult to replace? My driver side doesn't work. Thanks. Best place to order?
Some have deliberately installed them upside down for knee clearance. Off the top of my head I’d think the spring could be installed in reverse... although I’ve only ever replaced one the correct way (with a similar one from a random winder).I have been using a replacement drivers door regulator(non-oem) for a year now on my daily driver and it still seems brand new. Very easy to install, it looks good, my old one had a dead spot on the gear. 73FJ40, I had no idea it was even possible to install them upside down, crazy.....
Hi. The window doesn't stay up at all. I wedge pieces of rubber in to keep it closed. I'm just assuming its the regulator. Does that sound like it to you? Thanks for your help.Are you sure it is the regulator and not just the felt causing problem with window movement?
I'll check tonight after work. ThanksDoes the ‘73 have a door card or cover that you can remove? Then you could watch the regulator, window and everything else.
Maybe the spring broke. It works like a counterbalance.Hi. The window doesn't stay up at all. I wedge pieces of rubber in to keep it closed. I'm just assuming its the regulator. Does that sound like it to you? Thanks for your help.
