70 Clutch Master
Columbia, MO
I've read a number of threads about replacing the clutch master/slave/lines etc. but am hoping some guys that have done it can chime in. The clutch master leaks into the cab and it appears the PO rebuilt it. I'm not finding an OEM version so am curious if anyone has used the replacement "kits" from CCOT or SOR as a solution or if anyone has a suggestion for an upgrade ie; use this year clutch master, this line, this slave etc.
My preference is to put good parts on her and not replace again for a decade+. None of the replacement kits are Aisin so likely just chinese stuff. Maybe fine?
It's an 11/69 build date so falls short of the cutoff for a different version C-master (7/70) but is a 3 bolt with banjo.
Land Cruiser Clutch Master Cylinders
$188
https://www.sor.com/cat018.sor
$135
Thanks thebigredrocker, it's been rebuilt previously. CruiserOutfitters has the same after market year specific models everyone else does it appears. Does anyone know how many times you can rebuild the clutch master and slave?
It really comes down to the condition and diameter of your bore. Assuming wear is minimal in the bore, you can rebuild 100's of times. However the reason they often need to be rebuilt is damage, pitting, contamination within the bore. Let us (Cruiser Outfitters) know if we can help. Thanks!
I have had leaky slave cylinders that looked good when taken apart and inspected but leaked when assembled and reinstalled. I can't remember how many years ago it was (10+) I put thin "O" rings under the flair part of the rubber plungers. Worked great for a bunch of years.
About three years ago I bought a new mc/slave setup with the SS braided hose. The slave started showing signs of leaking about year ago. I pulled it and did the o=ring trick. It is working better than original in my opinion.
I have done similar on the clutch master with some success.
Don't even think of doing it with brakes.
Hiya, The clutch MC/slave rebuild is pretty quick. i think i clocked my last one at ~ 2hrs on a saturday. I upgraded from the old one on the '70 fj40 to one that covers from '74 to 1980 so I can buy an extra mc & slave rebuild that will fit both the fj40 & the fj55 and usually easier to find. i always run a brake hone in the cylinders when I rebuild & if it feels a little rough on your finger afterwards, it's likely you'll be looking at a new cylinder at some point in time.
good luck, ty
:beer:
Recently bought a new clutch slave cylinder from NAPA for my '86 FJ60 project vehicle. It's new, manufactured by Aisin. I'm pretty sure it's the same with my new NAPA master cylinder.
Re-boxing is very common in the auto parts industry.
