#7 Freeborn Red bodywork and paint (Bean)
Not bad. I haven't even block sanded the primer yet :cool::cool::cool:
what are "low spots"? And what happens to those? Filler? ty
When sanding filler, sometimes there are high and low spots that you cannot feel or see. In other words, waves in the car or body work if that makes sense? Also, small dents or dings are mush easier to locate with primer and guide coat. Here I used light gray primer, then sprayed guide coat in black on top of the gray. I then use a block to sand the panels, and since the block is flat, it doesn't sand into the low spots, and sands through the primer on the high spots. As you sand, the black guide coat stays in the low spots so you can locate them easily and the high spots are bare metal. Sometimes the high build primer fills in low spots while block sanding, otherwise I use a filler. Then I have to prime and block sand again. It is quite the process. Basically though, primer is another type of filler really, especially high build primer that I use.
counting the days.....
  • Like
Reactions: KTP
