No fun in that!now I know why people spend big bucks for someone else to build a rig for them!!!
Better to do as much as you can. I didn’t know anything when I started the restomod of my 1969 pig. When I converted to disc brakes on all four corners my mechanic friend showed me how to do the first corner and then said I should do the other three. He then added that since brakes are pretty important he would check my work. When I put in new shocks he said that I should be able to figure it out myself and if I couldn’t then I probably shouldn’t own a classic 4x4. LOLits been a lost summer when it comes to the build. I did get one tag this yr but my son got 3 so for those of you who hunt know this takes a ton of time. Daughter went away to school and other life stuff has slowed things down but im getting back into it now. fuel filter has been placed and all the fuel lines installed. the brakes were not fun. if you are not a brake guy then there is a learning curve. wildwood sent me parts that are metric, standard and pipe thread and when you do not have instructions then you have a mess. I finally talked to someone who knew what was what and hooked me up but i wasted 2 months and many hrs on a simple project. now I know why people spend big bucks for someone else to build a rig for them!!!
That is a lot of stuff!more stuff
I cut off the bottom section which held the vacuum transfer case knobs/pulls so that I could tuck the Vintage Air unit up tight. That caused a problem with the original glove box door which I replaced with an aluminum cover and piano hinge. The upper area I used with a matching aluminum plate for original wiper switch, a vintage BMW hazard switch, a concrete style plug, and a two USB outlet. I have since replaced the cigarette style outlet with a Bluetooth “200w” amp and music labeled knob available here on MUD somewhere. Even with the loud 2F I now have music and podcasts that I can hear above the roar of the engine. Love it.Great build!
Pondering what to do with this area. Considering some gauges (voltmeter) and charging port for phones or whatever.
Any plans on what your going put in there other than the Missiles to guns switch!
Saw how your vintage air fit which is reassuring.
Yep…crude but that was how the Land Cruiser logo plate was attached at the top of the center dash so I thought o would keep it consistent. At least that is how my 1969 was done.OK thats good to know. It looks like you just bolted into the dash?
