Build ‘68 M715, AKA "Smokey" (Can I post this Jeep on MUD?)
I have no doubt that it well look much better when your done with it.
Hey thanks!
The plan is several strong backs and a LOT of clamps
Started patching the tailgate back together
Coming up with a battle plan…
Cleaned off the old hinges and the nonsense. Cut a vertical notch in the ribbing. Welding 1/4” thick material to 14G body was a bad plan from the Kaiser engineers
Cleaned the nasty mill scale of some 2.5”x 3/16” angle iron and added a load of clamps. Basically clamped it to within an inch of its life as I slowly tack welded down it
On to the upper portion. Pretty damn bent
I knew there was a reason I kept the old bedside sections after bobbing it. The radius is the same as is the metal which is 14G
Added the portion with the radius back in after clamping everything flat
Fully welded out the bottom portion
Nice to weld on something cleanish for a change
Top portion will be capped and reinforced with the same angle iron like this
Done for now but it’s much closer to where it needs to be
More tailgate today
Put strong backs across it and clamped the hell out of it
Replaced the damaged vertical sections
Cut out a repair piece for the other side and welded it in
Fully welded here
Close but not quite. Much better than what I started with. I’m going to try and hydraulically press out what little bend is left
Sorted out the console mounting and found a place to relocate the Tuffy console cup holder lbs to
Also mounted the intercom inside the console where it’ll stay dry and added an interior light that operates off a mercury switch
Radio/intercom stuff
Found a mounting spot for both the driver and passenger Push To Talk intercom controls
Mounted the intercom jack plate into the rear of the console
Pulled the headsets out to get an idea for cable routing
Fairly tight on the rear of the console but overall a good fit
Not much to report but it was nice enough outside to pull the truck outside to sweep the garage floor
It’s a BIG low slung truck seeing it outside
And here’s a quick overflight. Forgive my crummy drone piloting in my cramped driveway
That reg should be a blast on the trail, can't wait to see it out in the wild !!
Haven’t posted in awhile, time to catch up
Rear shock support, removable
Windshield dash bar, 1.5” DOM
Supports for comm headsets and a truck rear view mirror
Dash bar
Wetsounds Bluetooth speaker
Installing a NOCO plug for the factory GM block heater
Fabbed up a dual radio head mount
Seats and seat belts
Windshield frame repair
The beginning of windshield latches. For holding it in the up position
Windshield latches. Stainless Destaco’s
Added a Tuffy lock to the glovebox door
