Build ‘68 M715, AKA "Smokey" (Can I post this Jeep on MUD?)
ECU....
Added the Gen 4.0 Power-Gate battery manager and the Switch Pros distribution block
And all thus is tucked up above the Vintage Air heat and AC unit
Knocked out a few small machining projects too
1.5” 7075 aluminum tie rod tapped for 1 ton TRE’s
Sky high steer arm and a tapered bushing from Ballistic. With how low this truck sits, I can’t put the tie rod up that high. However, the passenger side arm will hook to the draglink and the driver will hook to the PSC ram
Had the arm drilled for a tolerance fit on the sleeve and also milled a bit so the sleeve fits down flush
This pic below is the under side since the draglink comes in from underneath
Wrapping up the steering. Billet arm from some racing application with a 1/4” drop. Was drilled for a threaded 5/8” bolt
Reamed for the 1 ton TRE
Installed. Draglink to panhard angle is just about identical so there shouldn’t be any weird bump steer
Mounting the tilt column was tackled today. Flaming River stainless column and mounting components, Sparco steering wheel
Support bushing at the firewall
Had to notch the dash just a bit for the upper support block
Installed and the DD shaft mocked up. Looks like I was lucky and I’ve got about 1/8” clearance on the edge of the motor mount. Works for me
Pretty slick setup overall :)
Turns out nobody makes heavy stainless flanges for the 8.1 liter, at least not that we could find. So....got a chunk of 1/2” 316 plate to start from scratch
Cutting this 1/2” with the plasma was slow but doable
Done:
Starting the exhaust. 3” 16g from the manifolds back. All mandrel bent with a crossover from dual to single.
Driver side:
Driver side underneath. Short flex pipe and a small cat because IH8STINKYEXHAUST
Hard to see but this is the passenger side. There is VERY little space to cross it over and the only option is bringing it back to the Magnum and doing it there. If I didn’t care about having a front driveshaft it’d be WAY easier
Crossover will be somewhat “close” to this here
Time for a little body repair on this 52 year old cab while I wait on some exhaust parts
Driver cab corner and rocker. Using a Blair cutter to
break the spot welds loose
Peeling away the cab corner
Up inside the rocker. 1st glance I got scared thinking that was a petrified rubber. Thankfully just a candy wrapper
What’s left of a battery. How this stuff gets inside a rocker is beyond me
Just a mess of spot welds
Rocker coming off...
Unfortunately, the new panels are only “close” to the original. I should be able to straighten it out with a sheet metal brake. These are made in USA but I suspect there are some small design differences between the civilian J20 and the M715
Cut out the rest of the bad spots today. This is the lower portion of the B pillar
Body work :(
Plasma cut out the last little bit, basically the very inside floor corner of the rear cab. I didn’t want to play around with welding anywhere near it
Cab corner fit-up. Overall pretty good. The only issue is that the corner radius is slightly different. I should be able to mechanically push it to where it needs to go.
Went ahead and welded nutserts into the tunnel. This way the shift boots and rings can be easily installed or removed without a back up wrench
I also cut out the hole for the Ranger a bit bigger to match the shift boot ring
Had it with all the tedious body work. Took the 40 out of its nearly 8 month storage and jetted over to Eastern WA for the day. This is up near Sugarloaf
Back at it. The hydroboost rod needed to be significantly shortened, I came up with this and it threads together securely
Started modifying the dash for all the extras it needs.
This was a big factory hole in the upper left section of the dash that needed to be filled in so an updated wiper switch could be installed
All silicone bronze filler here
Laying out the locations for the SwitchPro and ARB’s
Cutting the hole for the Vintage Air climate controls
Time to cut up the frame a bit. In order to maximize uptravel with only 2” of lift, the frame needed to be relieved for the panhard bar. Max uptravel will be 4” as just beyond that the differential casting strikes the frame and the panhard is in the front differential cover and engine harmonic balancer.
Used a chunk of DOM that I bought awhile ago for doing this same thing with the bump stops
It’s VERY tight at full bump but it’s in
About a 1/16” of clearance on the draglink at full bump
Also ended up modifying the factory GM pedal a bit as it was protruding WAY too far in towards the seat. Cut it, ground it a bit and bent it out some towards the brake pedal. Now at least both are “on line” together.
This also clears room for the installation of the cutting brakes
Notched out and tubed the rear frame in preparation for the bumpstops
Plasma cut then cleaned up with a flap wheel
Using 2.5” King bumpstops
Got a big welding helmet upgrade as a birthday present. Unbelievable how well you can see under this hood and the color while welding appears like natural light
Which model did you get, l have been eyeing those?
It’s the Crystal 2.0 After reading reviews that’s what I wanted to go with. Welded multiple hours today and it was fantastic. Worked well with the plasma too
I had these old suspension brackets sitting in the metal bin, decided to cut them up to fabricate bumpstop pads
Fully boxed and burned in
This is 5” total uptravel
Started cleaning up the rear frame which was full of old holes
TIG welded with 70S2, sanded, then the small gaps filled with silicon bronze. Finished with the DA
Welded the rear frame plate in after plasma cutting holes for the shackle mounts
These are fully passed through the outer and inner frame. Solid 1” bar from Ballistic
Tying in the plate...
DUN
Picking away....
This is the mount for the cutting brakes
