corbinwelter;whats with the blue????[/QUOTE said:That's early SBC color. it's a .......010, '69 - 4 bolt main short block ............ I don't care for orange![]()
whats the latest?? got my r4 and new 4spd TC ready to rock, now just trying to figure out my cross member options for this conversion
The rear brakes look like 80 series. Are they stock on the FF 70 series axle? All years? What are your plans for the parking brake cable & lever?
looks like FJ60 TRE's on the right hand side. Notice the TRE from the drag link connects to the tie rod off-center above the center line of the tie rod. Both FJ60 and FJ80 TRE's are this way, whereas the FJ40 TRE is centered.
those are 70 series tie rod ends. the 60 and 80 series ends may be off center right to left of the end but I'm not seeing how this would cause twisting? the set up I'm running from steering arm to steering arm is mechanically identical to a stock FJ40, only beefier.
It looks like you have stock clamps on the tie rod so maybe that won't be a problem. There will still be some added slop since the PS box has to twist the tie rod against the TREs before the side to side movement starts.
Whose PS kit did you use? I like that "strengthening plate / curvy thingy" they provided that you cut your front crossmember to match.
its Luke's from 4X4 LABS, solid kit.
Seems like an auto would give me a better crawl BC of what the torque converter does.
auto basically doubles, depending on the torque converter.
do I need to worry about the "weakness" of a 4L60E
not sure of any "weakness issues you'll encounter, but you will have that ECU module to deal with.
My dad already cut out the rear 'wells for wheel flares and did so centered over the stock location of the rear axle. How much does turning the springs move the axle back?
Looking good!
What are you going to do for a parking brake?
After a second look I see the internal drum/disc rear brake. That is a great option for a parking brake.
Can you tell me which Lokar shifter you used (part# if you have it)? I'm doing the same thing and am looking for a shifting system for my 350 & 700R4.
I have a similar set up in the works. How much lift you shooting for with the 700R4? .
X2!!!
What is that, and how does that work?
Can you do that to a 60 series rear semi float?
