63-67 Front Heater Core
Montana
Well my front heater core finally went today spilling coolant all over my front floorboards. Does anyone know where I can get a new one or at least a good used one?
I may have one extra one, here in Helena, I'll look later when I go into the shop.
Paul
I really only need the core, I just refinished my old heater box so it looks cherry. I have it out and the hoses bypassed for now.
are you sure its a toyota heater my 64s and 65s had aftermarket heaters in them and 1 never had a heater i have some cores from all years but would like to be sure thanks
I have a good one from that era. It is the entire box that bolts to the dash. How does $50.00 plus shipping sound?
I'll post some pics.
I will take the whole heater IF its solid. Please PM me.
I have a good core, that is the only one I have ever removed that was not in pieces due to the brackets breaking. If you want a good core. 63-67 cores are thicker with 4 brackets, two on each side.
BUT you can use the later model cores with twice the foam wrap to fill in the gaps as it must sit an a slight angle in the housing and will not be bolted in.
no replacement cores for the early heater, latter cores might work with some mods.
Paul did you have an extra.
I've got both a complete unit and one in pieces with good core but 2 of the 4 soldered on threaded pieces are off, you could solder them back on.
I'll PM you my #
