62 skids when braking hard
Hi my fj62 skids whenever I need to brake quickly, any ideas on what is causing that and how to fix it?
Sent from my iPhone
It's caused by you pushing the brake pedal hard and the brakes doing their job. You can fix it by a number of means, firstly with driving habits. There is no ABS on an FJ62. A 25 year old truck needs to be respected for what it is and what it's not. Jamming on the brakes in an FJ62, even one with perfectly working brakes will not produce the same result as jamming on the brakes in a new Camry.
We need more information to be able to help. Now if the problem is that one wheel in particular or one axle is locking up too early, then there is certainly something wrong and you need to properly diagnose the situation before proceeding. You could have a sticking caliper, improperly adjusted rear brakes, etc. Post up exactly what is happening, and any details that would be of help; were the brakes recently serviced? Has it been 10 years since a wrench touched the rig? Has it been sitting for years? Is it modified?
Grease the disks helps but kids always like their A-team neighbor so why stop sideways drifting?
Sent from my iPhone
Experienced the same previously - master cylinder fail, only the rear brakes were working. Skid, like scary drifting in a 60 skid.
Sent from my iPhone
Do you know which tire or tires are locking up?
Do you have a lift? Are your tires in good shape?
Since the 60 series does not have ABS, there will always be a point where the force being applied by the brakes exceeds the friction between the tire and the road surface. That is, "skids" can happen.
The 62 has a load proportioning valve for the rear brakes. It's designed to change the braking force to the rear axle based on the weight in the rear of the truck. Suggest you check to see if this is working to spec.
The rear drums might be adjusted too tight, or one might be tight and the other loose. Lots of reasons why this could happen and either or both could cause the rear wheels to lock up sooner than needed.
There are other possibilities also...
You might want to test your brakes (locking them up) on a gravel road with the windows down, so that you can hear/sense which wheels are locking up first. Ideally, all four would lock at about the same time.
