Great job sir.
Need to stop by and see the progress on the Cruiser.
@cliffrdavis, were you able to use the hub dust seals with the new hubs?
You can, I flipped mine and trimmed the flange to fit
You must’ve got the 2017+ 4Runner kit (what I have as well). With the additional bracket spacer it pushes the seal out too far and interferes with the hub. I cut the flange off the old seal and flipped it around for a mockup/ test fit and it clears the hub.I don’t remember why I flipped it, but I assume it interfered otherwise I would have left it intact. YMMV, fit it up and check
Yup same kit, makes sense now!You must’ve got the 2017+ 4Runner kit (what I have as well). With the additional bracket spacer it pushes the seal out too far and interferes with the hub. I cut the flange off the old seal and flipped it around for a mockup/ test fit and it clears the hub.
The seal really shouldn’t be oriented this way. But for a dust seal it’s better than nothing.
