60FZJ-UTE 6 X 6 CUMMINS 24V 5.9L CRUISER
Hydroboost is ordered.
Went with a new Bosch 2010 Chevy Silverado 2500 booster and AC Delco master ( 315.43 cost with shipping). About 1/4 the price of a Wilwood setup. I'll make an adapter plate for the firewall and decide on a proportioning solution after a bit more research. More than likely an adjustable combo design.
Jason
TT
Seats and fabric
RCV is supplying the axles on this build.
Front Eaton E-locker supplied by Georg at Valley Hybrids @orangefj45
Will have the front 80 axle with TT custom pinned knuckles and Hi steer built in the next few days.
Jason
TT
Door cards are done. Interior parts are off to the upholsterer.
Scheel-Mann vinyl, fabric, padding, carpet, OEM inner window belts for all 4 panels.
Ash tray delete on the rears and opening up the front panel speaker holes for the Hertz 6.5" MPK 165.3 Mille Pro speakers.
Jason
TT
Well that's different
More compact than our OEM systems. Can be removed as one unit with 4 bolts. 3 year warranty and parts are available on most any online AC supplier in a pinch.
Has a bluetooth app (not my cup of tea) but cool (ha) for the masses.
With all the options I chose 2693.00
Jason
TT
Ordered the new AC evap unit (AC, heat, defrost) and accessories.
J
I put the same manufacturer but the smaller size in my 40. Just an FYI, I had to build a box under it to support it, after a couple years the plastic box was beginning to crack at the mounting points. I noticed it started moving more than it was and when I investigated, that is when I found the case breaking. It is all good after the switch panel I mounted under it for support. I run mostly rough forest roads. So not anything hard core.
It comes with two supports. The weight is balanced back and bottom now. When I looked in the past it was firewall support only. Also I will tie/support it into the new lower dash I build.
Jason
Headlights ordered. Dapper Lighting LED OE7
