- Joined
- Jul 22, 2012
- Threads
- 639
- Messages
- 17,621
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
How much of the truck's mileage is in 4wd?
One of the coolest builds I've seen. Love the truck..and I'm jealous of your shop.
And a couple shots of the "carnage" on the drivers side. The washer was probably done by a loose wheel bearing, but the birf? Any suggestions? Loose wheel bearing too?
View attachment 1183398 View attachment 1183399
Birf damage was also caused by the extremely loose, if not completely failed, wheel bearings. When the wheel bearings get bad enough, they allow the outer edge of the hub to tilt up towards the hood. When this gets bad enough, since the birfield stub shaft is connected to the outside of the hub, the birfield shaft will rub on the upper portion of the inside of the spindle. Check the upper half of the inside of the spindle and you'll see wear there too, where there should not be.
Absolutely loving the truck! Fine work!
Here is what I did with the fuel filler. It remains to be seen whether or not it will fill. The vent is on the bottom side which is not ideal. I think in the future I will get a neck that is a straight shot rather than a curved neck. I need to build some sort of heavy "mud flap" to protect it as it sits.
I also removed the vapor separator mess and ran one of the smaller vent lines to the charcoal canister - we'll see how this works out. I can reinstall if it turns into a problem.
View attachment 1147059 View attachment 1147062
Unfortunately I have some harness work to do due to a shorted solenoid during fall crawl so I can't commit.On a separate note do you want to sign up for wheeling 4 hope?
I put the whole fuel vapor separator in a bed mounted tool box on my fj55- you're going to need some sort of separator canister or you will risk getting raw fuel up to your charcoal canister...truck looks good!
I just checked and they only have 9 registrations left!! Good for them, it's a great cause....
it is for day to day expansion and contraction of the fuel, based upon temperature changes. the fuel evaporates readily, and it's vapors are trapped, compressed and condensed inside the vapor separator. the re-condensed fuel returns to the tank, and the gaseous odors that don't condense are routed thru the charcoal canister. you should do something about this before alot of driving...the vapor can needs to be above the level of the fuel, so just higher than the tank will work. Inside of a tool box, or maybe tucked between the headache rack and the rear firewall might work without being conspicuous.
Cool..Thx!. Same here.Is this for normal driving conditions? or mainly off-camber or roll over situations when fuel is somewhere other than the bottom of the tank? I'm mostly wondering how concerned I should be about this.
Yeah, I think there is a waiting list now. If you need some help spinning wrenches i'm always game.
