Nobodies (most) gonna wanna cut into the cargo area...
Yeah it wouldn't. I just can't see anyone in their right mined want a 3 link with a 2 inch lift.My bad. I guess you can but it would seem like doing all this work to be limited would not be worth it.
2 inch lift is a joke. Action Jackson ran a 3 link with 6 inch lift and stock steering.
Would you buy it if it worked with stock steering? Odd constraint you're bringing up.It's just the fact if your in this deep you are probably wheeling hardcore trails that require a 6+ inch lift. The bellies on these things are a big limiting factor.
I think it will work but he just doesn't recommend it.Would you buy it if it worked with stock steering? Odd constraint you're bringing up.
Well I've upgraded my steering with hydro and it works mint. Is that not enough?True. Very true so why use stock steering in that situation? Why be in that deep and stop your upgrades at steering.
I understand. And I'm at 6 and mine is not flat. It handles decent on the road. But it is not my DD.Hey if you want to try it go for it. I'm not saying it doesn't work in fact it should have less bump steer than Jacksons. I'm just picky and would tell someone that at some point hi steer is going to be better. The flatter the panhard is to the ground the better the performance. You can't have a 6 inch lift and stock steering and have it flat.
Sort of, the taller/flat roll axis brings some of that in check, but you're working with a loaded school bus and that body is like a pendulum of huge proportions. Probably why so many jeeps don't use hardtops and so many toyota guys like pickup cabs.I think it will work but he just doesn't recommend it.
So far it's working mint.How's the hydro workin wrench? I've got a psc ram and tapped box but need to mod the pump I think(spring shim and 11/32 on the orifice I'm guessing)
