Basics: 88 FJ62 with about 135k miles. Only had it for about 2 weeks and still learning her quirks.
Problem: neither the 4H transfer button light nor the 4WD light on dash come on when the car is in either 4H or 4L. The 4H light came on once when in 4WD, then went out. I tapped it a few times and it came on/off, but that trick hasn't worked since. I caught the dash light come on once - can't remember if I was starting the car - and it hasn't since lit up since.
What I've done:
While I was under the truck, I do some looking around. Besides clearing out what looked to be a (vacant and old) rats nest, I found a hanging, disconnected wire. I am having problems posting pictures, so let me try to describe the problem. There are two sets of braided wires that appear to come down from the top of the transmission. The pair that isn't cut, connects to a post about two feet further towards the rear. I have no idea what the post is for. I searched around for the other end of the cut wire and I cannot find a logical home. Could this have something to do with my problem?
Thanks.
What I've done:
- Read a ton of threads. You guys are awesome
- Looked for both lights during start up - nothing
- Checked the drive shaft...seems like 4WD works. I climbed underneath and this is what i found:
- With the truck in 2WD, drive shaft moves freely.
- I pressed the 4H button, drive shaft does NOT move and neither light shows up.
Thanks.
