4spd tranny weight
With or without top cover? IIRC, somewhere between 110 and 130.
with the top cover, wow that is more than I thought, I have a 3spd lying around and it couldn't be more than 70 pounds cause I can move it around with no problem, I figured the 4spd would be close the the 3spd
Thanks for the info 65
wow thats more than i would have thought to, i can handle easily the tranny and case bolted together carying it around the shop or to and from the rig, i recently did a marlin toybox in the mix and with all 3 bolted together getting it off the bench and onto the tranny jack was about all i could muster.
JP STOP!!!!! Go to Help, I'm stuck, the guy had his tranny stuck in reverse and the guy told him how to fix it. Plus there is an adjustment on the side of the tranny for reverse. You may not need a new tranny at all. Later Chuck
Thanks for the tip chuck, that might be my problem, but my tranny also pops out of first when I am not accelerating and it also whines, I believe it has well over 200,000 on it so I am gonna just get a lower mileage used one, so I don't have to worry about it anymore........
JP
oh, hey chuck...
i went over to rick pate's the other day and picked up the clutch slave stuff that he was saving for you...
when do you want it? i can drop it off sometime if you'd like...
shoot me a PM
malphrus
