Sorry I advanced for many question to come. A newbie to new world of LC. How do you put/ know when your in 4hi? I put the LC in 4hi and the truck does not move forward or backward. I put it in transmission in neutral and shift it to 4low Than shift to drive and the Truck moves.
Am I doing something wrong.
Thanks!!
is this a US spec 80? if it doesnt move in 4hi but does in 4lo then i would start by making sure it isnt missing a driveshaft, front diff or something else obvious. i have a seen, more than once, an 80 without a front driveshaft using the CDL fuse trick to make it roll.
That's want I was thnking. I shift it all the way to the top for 4hi and nothing, I put the transmission in neutral and pull the shifter all the way to bottom and the ABS indicator comes on, on the dash and you can feel it's in 4low.
Is there an on the dash indicator that also comes on when it's in 4hi?
If you are in 4-hi, but moving nowhere you should be able to have someone carefully watch under the truck while you try to drive it (making sure they won't get run over of course) and if you are in 4-hi but having a problem in the front end drive train, the front drive-shaft should spin while you try to drive. If no drive shafts are spinning, then you probably aren't getting the transfer case all the way into 4-hi. If it is spinning, definitely a front axle problem of some kind, possibly a stripped spline.
could be the spline inside the driveshaft or it could be an issue in the front axle. i have seen people bust a birf and then just remove it and never put anything back in there. i would get someone to watch the front shaft and you SLOWLY let off the brake and see if the front shaft spins at the Tcase and at the axle. if one end spins and not the other then you just need a new shaft. they are cheap.
Unless it has melted down (and even then they usually fail locked up, not freewheeling) the viscous coupler would help the truck at least move even if the front drive line is out. It'll feel like the transmission is slipping, but it should move.
Are you hearing any grinding or anything?
Can you "feel" the three distinct positions the transfer case shifter should be in? High, neutral, and low?
With the transmission shifter in park and the transfer case in neutral, does a special light come on the lower strip of the instrument cluster?
Or maybe I will just hook a GoPro and see what it does. So shift to for 4hi and see what happens under the truck to see even anything is spinning. I would like the truck to move in 4hi. But like I said it doesn't move at all.
Is there an indicator on the dash that tells you that your in 4hi????
No grinding, and yes I can feel the neutral and low, but nothing on hi. And when in hi I put in "D" for drive and the truck does not move at all.
Did not notice a light on the instrument cluster. Only when it put it low, the ABS light comes on.
Thanks for your reply!!
Well, it should move. Shifter in neutral, move from 4lo, to 4hi, past neutral (should feel distinct shift for all 3 positions in transfer case). Then shift into drive and go. Indicator lights should turn off and you should be able to go.
It sounds to me like you are not making it into 4 high and staying in neutral. Are you parked on a flat level surface when u are shifting? It's possible that someone worked on your truck and the linkage has become out of sync. I think u can check if you are in 4 high by doing the following:
Set the parking brake
Put transmission in neutral
Shift to what u think is 4 hi
Jack up one front wheel
Try spinning the wheel. If the t case is in neutral you will be able to spin the tire and see the driveshaft spinning. If your t case is in gear it should move a little and stop.
