Okay went home and tried the 4wheel drive.
The truck only moves forward and backward when transmission drive or reverse and 4WD shifter in 4hi. If 4WD shifter is in neutral I get A/TP on the dashboard and as soon as shift to reverse from park the A/TP goes off and the truck won't go forward or backwards.
I put the trucks transmission in neutral, 4WD shift to 4hi the truck move back and forth. Put the shifter in 4low it moves forward and backward when I put it in driver or reverse.
When I go to put the 4WD shifter back in neutral with transmission in neutral and then try to put it in park very slow it want to grind the transmission gears. In order for it not to grind the transmission gear I have to put the 4WD shifter in 4hi while still stating transmission neutral and then I can shift from neutral to park on the transmission. With no grinding. So Ian I driving in 4hi all the time?????
Sent from my iPhone
Sent from my iPhone
