460 in an 80
The question would be: why retain a bad geared transmission with that engine?
No, it would not work out at all. Think electronics.
Think progressively here.
Slee got a 4.7 (early version) into an 80.
Later 4/7 would not work due to electronics (in the 100 series, not 80).
A 4.6 can only be worse in the same respect.
We need a genius to break the code on the Toyota ECU and turn off all the electronic stability control parameters, emission control systems, traction control, ABS in relation to everything mentioned already, etc.
It needs to also work with the 6 speed transmission as well.
The 4 speed in the 80 is a bad transmission period. End of discussion.
Try mating the new powertrain to the transfer case. Think adapters.
After you solved all this stuff, think how much money you are willing to spend on such swap.
As a point of reference, Slee is charging $25K just for the engine swap (4.7), retaining the transmission (yes the bad one) and everything else.
I believe he's talking about a big block Ford 460 :eek: No personal experience, but I think the wiring is pretty dumb on one of those.
It would definitely pull up the hills. I'm not aware of anyone who's done a ford swap in an 80, although there was a pretty bitchin' 5.0 swap done in a 60-series.
Look into the other V8 swap threads to get an idea of what would be required as far as electronics and adapters. Nothing would be the same as those, but would give an idea of all the little things that add up in addition to you having a lot to figure out as the first one doing that engine. Anything can be done with enough time and money, but that free engine becomes very expensive. I think it would be cool as a trail rig if the rest of you fj80 is fairly trashed to where doing it on the cheap (redneck style) wouldn't be a big deal. You could use a Ford trans and transfer case, move the fuel tank to the cargo area of the truck since it would not fit with a centered rear driveshaft, and either swap in one ton axles or see how long the Cruiser axles live with massive torque. It would probably be cheaper to buy a full size bronco to put it in and have two trucks than to adapt it. I researched swapping in an LS and decided to put my LS 418 along with superduty axles into a Bronco I found for $500 that was straight and relatively original. The Bronco/Ford guys will hate me, but I chose the drivetrain before the body.
A Ford 460? lol AWESOME! :steer:
More power and about the same fuel economy and would sound pretty bad ass.
Methinks you would be in uncharted territory. weight and size wise you should be in the ballpark, but getting an adapter to the transmission is going to be the tricky part since no one would make it and it would be pure custom
For reference.... if it wasn't redneck it wouldn't look quite right
I don't know much about the 460 because I don't pay a lot of attention to Ford, but a cursory glance on Wikipedia strikes me that it's a big dumb engine from an era where specific output was choked to the point of hilarity by the feds. I'm sure there's potential once you start throwing parts at it, like there is with any engine. And it's free, so there's that. But what if a Civic engine was free? Free doesn't always mean it's a good deal and worth the time and cost to get in there. Personally, I'd sell it and the amberlamps it came in and use that to get closer to having a proper modern engine stuffed in there.
As for having 86K on the engine... well, by modern standards that's just getting broken in, but by the standards from the era in which that engine heralds, I'd say it's a high time engine.
As for Toyota driveline durability behind any engine- it's purely subjective. How do you drive? What do you drive on? Tire size, lockers, ect. all factor in as well. Considering there's guys with 400+ HP Land Cruisers out there, I'd say you're probably good to go with the caveat of "depending..."
Anyway, that's my hot take on it. Do whatever you feel is right. :)
Big blocks cost a fair amount of money to build. Take a look on ford forums at what Ford guys are spending to get decent power out of them. Fuel mileage would probably around 13mpg at best. I doubt the axles would handle it, you would probably have to look into some 14 bolts front and rear. In addition it is a heavy motor, probably about similar weight as a 3fe. Probaby could be done up for 15k if you did everything yourself and use used parts where possible.
On the East Coast I need wheel speed. The 3fe just does not offer that. On long slick Hill Climbs you really notice. So no I don't need the swap it. But there are times when it would be really nice. And like I said since I getting this engine next to nothing I'm looking at my options. But I just got off the phone with Advance. They do not offer anything
You can pick up 5.3 Ls motors for around 500ish or sometimes less if you look around. Plenty of people have done it and the aftermarket support is pretty strong. A mild cam and headers will get you 400hp. Headers for any v8 would be the tricky part.
I know.... and I really want to go
4bt but that wouldnt really help all that much
"As for having 86K on the engine... well, by modern standards that's just getting broken in, but by the standards from the era in which that engine heralds, I'd say it's a high time engine."
X2
Although the 460 only has 86K it came out of an ambulance...that's like saying "low mileage police car, only rarely driven like a lunatic"!
LS motor...way mo betta
Turn the Ambulance into a 4WD expo/rock crawler/mad max apocalyptic rig and put a better mill in 80. IMHO:beer:
