Put the top back and doors on to check clearance for the cage and found the tub is bent. Called the insurance co and they want me to take it to a shop to see if it can be pulled, so I buttoned up everything else. The passenger door is about 5 degrees out of square. The cowl must be tweaked pretty good.
Picked up the windshield and installed it. Got the top on and bolted down. Got the VSS in which required pulling the brake drum. I used Marlins square wave pulse generator, but it hits on the e brake cable enough that it will only fit if put in before the e brake backing plate. Installed the mirrors, fuel filler and spare tire carrier. Got the front clip all rewired. Built an air box for the Spectre air filter. Adjusting the shift linkage was a giant pain.
