45 drum to disc
I have a 77FJ45 with a front drum axle and I'm hoping to make it a disc one. I have read as much as i can and here what I plan on doing. Just looking for conformation more than anything. I want to use knuckles out from a 83 BJ60. It has the vented rotors. I also could get the knuckles out from a early toy truck....but it has the solid rotors. Pics of the donnor axles can be found here.
http://photobucket.com/albums/a187/arnott1t/Disc Conv/?sc=1&multi=6
I would use bj60 outer birfs too.
Think this would work?
Tyler
I am pretty sure that you could us the BJ60 parts. I cant imagine that they would be different from an FJ60. I used FJ60 parts to convert my 69 front axle to disc brakes. That is just my guess though.
arnott1t: i just did this swap a few months ago on my 74 fj55, an acording to my research then all fj40/45/55/60/62 knuckles are interchangable ecept the ball&claw style axles. inners all have a 27 spline interface with the birfield, keep your inners swap everything else. hope this helps, carl.
Did this conversion on Junk's '77 FJ45 from Canada. Used knuckles out from a '87 FJ60. Used the FJ60 tie rod, shortened to fit. Did this 'cause the 60 steering arms use a larger diameter tie rod taper than the 40. I "THINK" this is where you can use a brass/bronze bushing from a starter motor to shim the hole to accept a 40 series tie rod. Search for posts from Texican about it. Also used the 60 relay rod (shortened too) and P/S box but that might not be part of your plans.
We borrowed a knuckle alignment SST to make sure the right shims went to the right places. A search will yield more details about that too. Also an entry in the tech section about it I believe.
I also had to grind the inside of the axle housing where the birfields go. Did this to the birfields would fit into the housing.
HTH,
Nick
you can use the 60 series parts just don't interchange spindles and hubs.consider the 60 hub spindle as a matched set and you wont have any problems .Large or small knuckle makes no differencs at all except for the steering arms you choose if you want to stick with the stock tie rod then you will have to find a pre 79 knuckle assembly as the tapers and bolt pattern are different .you could also use the 60 seriies knuckles and get taper shims for the tie rod ends from the stock 45.Again the axles will have to be clearanced to fit the 60 birfs.
If you get the late FJ40 steering arms(79-84) then you can bolt them up to the FJ60 knuckles, and not have to mess with tierod lengths and using bushings. This is what I did.
