40th Paint - Recommend a Brand?
Has anyone here had a 40th with antique sage pearl repainted? I have a right front fend that will have to be re-shot, as well as some blending into the hood, and I'm worried about having it come out looking less than stellar. The local shop that my insurance company uses for lifetime warranty repair work uses PPG.
1.- What paint company makes the best replica of factory antique sage pearl?
2.- How many coats of clear should they shoot? Do I need to ensure that they shoot multiple coats of clear with wet sanding in between?
3.- Any other advice?
You could paint it white like the PO of mine did. :bang:
1) Spies/Hecker or Sikkens
I have a bodyshop and have used all brands of paint....
If you want the best, go with either Spies/Hecker or Sikkens...
PPG will work fine, but S/H and Sikkens are far superior and preferred by most painters for quality matching :cool:
Unfortunately, the good stuff doesn't come cheap :frown:
When I repainted my T/A, the S/H paint supplies alone came out to just over $1300 my cost :eek:
2) The amount of clearcoats differ for every color because it changes the tint, but it's usually 2-3 coats....
If you're only doing a partial paint, you need to follow the guideline for that particular color for a perfect match...
However, if you're painting the entire truck, you can add a few more coats in between sanding cause everything will match anyways :)
I went with 7 coats of clear on my T/A for depth that's just unreal :cool:
3) The secret is all in the prepwork....
Most shops will just use a DA and call it a day, but if you want it to be perfectly flat with no waves, make sure they use a long block...
You can have the most expensive paint out there, but if the surface isn't prepped properly, you might as well be shooting it with a rattle can :doh:
My 80 was refinished with Sikkens in 1998 and the paint on the roof and hood crapped out in 2006-7.
It was re-done last year with Sherwin Williams (same body shop) and so far that finsh is looking very good.
In my opinion you would be making a mistake to roll into a body shop a dictate what brand of materials to use.
A shop gets used to using a certain line of products. They know how the different coatings (primer, top coat, clear coat) interact, how to color match existing paint, how to get the products to do what they want, ect etc.
Most shops I know of will only warranty their work if you let them do it the way they want to do it. Most that do insurance work give a lifetime warranty. If you do not like the results take it back till they get it right.
Others may have other options . . . .
True.
Case in point my shop. The did not want the re-shoot the truck Sikens because their current bank is SW and that is what they are more comfortable with.
Thank you for the advice. I'll think I'll check paint brands at a few non-local shops that have been recommended by the local chapter and see if my insurer will warranty their work. If that doesn't pan out, I'll roll the dice with the local PPG.
