Build 400HP 6.2L LS with 6 Speed auto swap....no lift. Plug 'n play swap kit in development
I'm starting on my swap in November. Bought a 5.3L 6L80 combo from pacific fabrication. It ships out monday. Going into my wife's 96 LX450
The guys at pacfab have a great reputation on pirate for supplying low mileage take out engines. I originally wanted an iron block gen 4 5.3 to go with the 6 speed but ended up with an all aluminum version with only 23k miles from a 2013 truck. No active fuel management for me.
I'm sure , just like most swaps i've done, the wiring will take the longest. Best part about the pacfab setup is you get a brand new custom built by them harness with a sealed bussman fuse block and programmed computer. Should be just a few wires to hook up to make run.
I'm sure i'll be asking a bunch of questions about getting the gauges all working though
Me too!
Is that the DI L83 motor? I was going to go that route till I saw they have an issue with valve deposits. Basically, since none of the fuel flows over the valves, none of the detergent has a chance to clean them. When I heard that I understood why all of my DI Toyota's have had two injectors per cylinder. Just a heads up.
Did you get anything else for the swap from them, like adapters, or just the engine/trans
whats been done to remove the active fuel mgt beyond programming? Where lifters / head gasket replaced?
The way I'm doing Gages, is using GM stuff for the ECM. Then adapting new yota senders to the engine for the Toyota gage cluster...
AFM delete I got my kit from Texas speed, comes with a cam (ls6 or ls9) and other goodies based on application, I opted to replace all my lifters. the Vortec/LS motor you can change out lifters with out pulling the head IIRC. Haven't got to this point in my build yet, so not sure yet...
I ordered an adapter from the parker store for my water temp sender. It is a hydraulic adapter made out of steel. 16mm x 1.5mm female to 12mm x 1.5 male. It will screw into the plugged hole in the head and allow me to use the toyota sender. It cost less than $20 .
I would love to see a step by step walkthrough of how to do this swap with a complete parts list that includes where to get all the parts. The rings on my 4.5 are shot, and this is my dream drivetrain for the 80.
