40 voltage gremlin 18v
tubalubb
what do you mean by "put it back together"?
Natchez, MS
hey gang my mechanic (who exclusively works on cruiser) called and said despite best efforts my 78 40 is putting out 18v. There are no aftermarket items, voltage regulator replaced, new battery, alternator ok etc. does anyone have any ideas? We are at a loss.
A Delco alternator will put out around 18 volts at full field. It's probably the same with a Nippondenso alternator. I'd look everything over thoroughly to make sure I had the proper model of regulator and that all connections were correct. Then I'd pop in another alternator, just to check.
Check for resistance in the wire between the battery/ignition switch and the regulator. This is the sensing wire, and any resistance will make the regulator "think" the system voltage is low, thus making the alternator put out more voltage.
18 volts will over charge the battery, shorten the life of incandescent bulbs and completely toast any led's you have. Probably not good for fan motors. I would suggest you change out the alt/reg to get it back between 13=14 V.
We’ve changed out battery alternator and regulator multiple times. It’s screwy. Ground is good too. Will check resistance between batt and ignition switch and report
We also ran a fresh wire from ignition to voltage regulator to eliminate factory wire. All fuses good. Fusible link not blown
Maybe a long shot, but have you tried to measure it with a different multimeter? Maybe one with fresh batteries?
At this point we are using pro equipment snapon. I think we are looking for a very large ground short (per coolermans initial email with me) so if all of the preceding facts are true where else on this rig could cause a short that large?
Where is he checking the voltage? At the battery?
Rob is a member here I’ll ask him to weigh in. Normally I do this hands on but he was putting the motor back in and it’s about 2o miles from me.
Can you tag a person? 0ffr0adlimo
This one doesn’t make any sense in anyway. Here is the rundown:
Amp meter pegged all the way to the right
Headlight fuse blown
Charging at 18v
Original regulator is toasted
Replace with new
Does good for 5mins then back to 18V
New regulator is now toasted (solid state aftermarket)
Alternator is removed and tested at the local Parts house, passed
Tested BLK/Y wire, 0.001oHm’s and not shorted to ground
Tested WHT/GRN and WHT/BLUE from regulator to alternator, good continuity and not shorted to each other
New OEM regulator. Once again charging at 13.6-14.3 then back up to 18V. Another regulator down.
Replaced alternator, and wired regulator independent from the truck, and once again back up to 18V.
Only logical thing to do but what are the odds of 2 multimeters, a Power Probe and lets not forget the Ammeter in the cluster that’s pegged all the way to the right to be wrong.
Other things I have observed:
The idle fluctuates when you unplug and plug back in the Voltage Regulator.
When you unplug the fusable link at the battery with the cruiser running and the headlights on one of 2 things happen:
1: The Head light bulbs will blow and the
parking lights get extremely bright
2: The Head lights and parking lights flash
My latest discovery the WHITE wire that connects to Ammeter is melted and the insulation is black.
I’m at a total loss.
Have you bench tested the alternator and regulator? If so what reading?
Regulators are completely smoked after failure so no reason to test, original alternator has been tested at the local auto parts store and tested fine, don’t know the readings as they picked it up to test it and brought it back besides have already swapped the alternator with a known good one that was removed from a running truck that wasn’t experiencing charging issues as well as a reman.
could the pully be sized wrong spinning the alt too fast????
never seen/heard 18volts before 15-16 yes but not 18.
is this at idle or at speed?
did this just happen? or was something done and now this is a problem?
Think out of the box. If you believe there is some circuit weirdness going on, pull all of the fuses out with the exception of the needed one to run the vehicle. Also, @toyotadan is correct that the wire that senses the battery voltage is what the regulator uses to increase charge. The more the battery increases in voltage, the regulator backs down.
( If the ammeter is pegged to right, the charging system believes it must really charge hence the overload. Remove circuits , fuses, to at least find a branch.
We changed the pulley last minute but my recollection is that it was original to the truck so I don’t think it’s spinning too fast. I don’t guess advance could cause this?
There where whisperings before the head/engine rebuild had to happen but I was convinced it was a bad alt/ red top optima or something. It drove great daily driver for years. After engine back in, winch is not reinstalled. Rob says it goes down to roughly normal with a headlight load. The only two aftermarket things are the winch and ac. Ac has been removed for sometime. Winch not really used just came with the rig.
many, many years ago I was running a groomer climbing a slope and all of a sudden the lights became very bright, turned lights off and it was charging very high 15+v, turned all lights and acc on and it brought the voltage down to low 13v, I got it to the shop, turned it off and it wouldn't turn over. the crimp at the battery, cable to lug on battery came apart. re-crimped it and all was good.
maybe you are having issues with the main battery cables???
