Sure! Bring your wallet with lots of long-wheelbase 10sas long as I got dibs on timmy, it is a good idea.
1971 Toyota Land Cruiser Jeep 4 Wheel Drive - RARE!! Runs!!
for whomever is/was looking for a project this looks pretty legit for $3K.
I would have him define "runs". Does it turn over or will it roll down the street at 45mph?
Price seems high to me...hard top?
Beautiful summary, SHUSH12/1974 was last date for the F.
74 has the 4-speed, 73 has the 3-speed, 76+ is disc, 78+ is fine spline pinions, 79+ is 3.73 gears 72-73 have the good lower t-case, 79+ has the bigger minitruck birfs and knuckles
74 and earlier had better sheet metal but much worse as far as parts, no 2f or disc brakes etc.
I would hazzard a guess that is what started the community swapping bodies or finding an early truck and converting to disc, ps, and a drop in crate v8
79 and up had weird rust issues due to a different paint technique
No reason the ditch an F for a 2F. None. Get that F purring and you will be happy.
Toyota 4 speeds are fairly easy to find. I like the idea of swapping the 3 speed for a later 4 speed for drivability. It is an easy swap. At the very least, there are kits that allow you to get the shifter off the column.
Disc brakes are very easy. You will have to get brakes from a late 76-up Cruiser or better yet, a mini truck. Best thing to do is buy SHUSH's truck because it has all the parts you need.
Brakes and new knuckles bolt right on the axle ball. You need the birfields too so that makes buying the axle whole the best play.
Couple of points....big birfs started 4/78 not 79, but the smaller knuckle pattern.
78 is only year with fine spline 4.11's until the 80 series rears.
