OK, there have been plenty of write ups for installing speakers, but I decided to do a detailed write-up, with pictures and most importantly, not use any dreaded aftermarket speaker grills...I wanted to remain as factory as possible. For the most part I believe I succeeded...I hope this helps some of you out that have been looking for a little more detail than has been readily available. I will post this installation over the next day or so...thanks for reading.
<br><br>
<br>I chose to use the thin Pioneer TS-G1644R 6-1/2" Two-Way speakers...I paid $39/pair for them...not to have high expectations, but I put these in my other Land Cruiser and they sound fine...definitely a bump up from the stock speakers which if you've ever take a look at yours lately are probably deteriorated. Note that I simply cut the speakers wires from the factory speakers close the speaker leaving as much speaker wire as possible...this enabled me to utilize the same factory terminal connection. I soldered the speakers wires to the new speakers...definitely the only way to go.<br><br>
<br>This picture shows the factory speaker removed from the front door panel. I used a significant amount of FatMat throughout this entire truck...more about that in another post...I have over three weeks of constant nightly installations...this truck is quieter without the door panels than it was before I removed them (almost impossible to believe, but true). This picture also shows the window rail shown just to the right of the center of the hole...this is the trouble with the FZJ80 Land Cruiser...there simply isn't enough depth to install a high quality, large magnet speaker...but trust these Pioneers sound fine unless you're a true audiophile. My main concern was to retain an completely factory look...so I didn't want aftermarket grills sticking off the doors. If you notice on your Land Cruiser when the door is closed the factory speaker grill is right up against the side of the dash, so it's even a tight fit for speakers surface mounted to the door panel...be careful what you choose if you're going that route.<br><br>
<br>This picture shows the new Pioneer speaker simply sitting in the speaker hole...the magnet is holding the back of the speaker against the window rail so that I can place a piece of blue painters tape on the door marking the mounting holes that I am going to use. The speaker is too deep and too large of diameter to fit into the recessed area of the factory speaker location, so I am going to modify the door panel slightly to secure the speaker...you will see why I am marking the mounting holes with the tape in the next post.<br>
<br><br>
