Ok so I know one needs the 4sp bell housing to swap a 4 for a 3, but what about the flywheel? Can I retain my 3sp fw and pp?
thanks
mark...
Hi All:
When swapping from a "three-speed (J30)" to a "four speed (H41/42) transmission" one must not only change out the bellhousing, but also the pressure plate, flywheel, clutch shift fork, shift fork pivot, and so on.
Regards,
Alan
Well, seems we have a difference of opinion here. Zulu... what about it didnt work? Anyone actually DONE this keeping the 3sp fw and pp?
thanks
Mark...
You have to have 4-speed everything... I tried, it doesnt work.
I blew through two throughout bearings in 2 months cause the PP was different. If everyone else is saying it works though, go for it. Maybe I just had bad luck...
Okay, Isn't the ID of the T/O bearing different between 3-speed and 4-speed? Its quite possible the PO of my rig mickey-moused my old setup together giving me the confusion, but I'm 100% sure I had to get a new colllar when i went to 4-speed.
The biggest difference in the flywheels is the early models had a step in the surface where as the laster flywheels were completely flat.
