TLC 1991 3FE
This started as a valve cover gasket job. Turned into an EGR delete after that. That turned into a head gasket job. The rabbit hole goes further my friends... Anyway...
I plan on taking the cylinder head to the machine shop for a pressure test, measurement and bath. Should I shave the head? If yes, then how much should I shave off? I would like to keep it minimal. While I'm in there, (since I have a lot of space to work with) what kind of headers are good for the 3FE? Any other ideas on how I can run a cooler engine with better air flow? Should I do a timing advance with the dizzy if I shave the head?
Or should I keep the head to factory specs and throw a turbo on later? I'm a mechanic but I have never gone this far. I figured a good 1st time project would be my own vehicle instead of somebody else s.
