Registry 3FE Owners Check-In
Vehicle Registries
I am quoting this from Mark W- old post...
"This is about as rock simple as it can be. No measurements, no math no special tools, no experience needed. Just line the BB up on the bottom of the timing window instead of the pointer in the middle of the window.
Bottom of the bb at the edge of the window is 12 degrees. Middle of the BB at the edge of the window is 13 degrees. Top of the BB at the edge of the window is 14 degrees."
The only way to make it simpler than this, is to tell you not to worry about timing marks at all... advance the distributor little bit...
if it pings under load back down some... if it doesn't you can advance a little bit more.
It is silly to try for this sort of precision without a dial back timing light anyway. And there is really little point. A degree or two is not going to affect how a stock 3FE runs.
Use premium gas will help with pinging.
Wonderfull, I love simplicity!! Thanks!
My neighbor has a 3FE, when I unscrewed the oil fill cap with the engine idling, it immediately started running like crap. Are these engines designed to run in a vacuum? Is this normal? Thanks
Nope... mine runs fine with oil cap off...in fact, it should idle normal when the valve cover is removed when adjusting valves when warm...
Yep. The 3fe needs to be pretty tight for vacuum & unmetered air.
The PCV system keeps the crankcase in a vacuum. By removing the oil cap you create a significant vacuum leak
Just wanted to show off my FJ80 at Moab - Poison Spider Trail
Thanks. Yes, we passed Brad's group and he was afraid our group would be slowing them down.....I went up the medium hard line same line Brad and Marco's (OverlandX) took in his 392 on 40s. Where he broke his rear axle as you can see from his video. View attachment 4121163
That’s awesome and inspiring to see a 3fe holding its own on the hard trails. Hope to get mine to that stage soon.
Got a new torque converter from cruiser corp and the bolts are lather than stock. I’m tapping the flex plate holes to accommodate newer larger bolts. Also had to re tap the upper tranny bolt holt in the engine block. Never a dull moment trying to re assemble the 3FE!
NEW PRODUCT DROP FOR MY FELLOW 3FE's!!!!!!
New Oil Pump Gasket Kit! Is it big, exciting or expensive... No.. Not at all. I mean for me it is exciting because it was a fun project and solved a problem I had and seemed the community needed. This kit comes with the pickup tube gasket (discontinued Toyota PN15149-61020) and the 2 copper washer gaskets for the outlet pipe (#15413D).
Toyota 3FE Oil Pump Gasket Kit – 80 Series Land Cruiser (1991–1992) - https://ruggedoverland.com/products/toyota-3fe-oil-pump-gasket-kit-80-series-land-cruiser-1991-1992
We will have another listing for a complete oil pump kit that includes this gasket kit with a new AISIN oil pump! These are in stock now and will be ready to go!
Oil pump is also available in one kit!! Toyota 3FE Oil Pump Gasket Kit – 80 Series Land Cruiser (1991–1992) - https://ruggedoverland.com/products/toyota-3fe-oil-pump-gasket-kit-80-series-land-cruiser-1991-1992?variant=52998316589378
Hey guys,
I’m looking at getting either the arb winch front bar or the non-winch bar. I’m trying to keep in mind weight with my already heavy vehicle. I’m not sure I’m going to run a winch in the future. I’m not opposed to modifying the non-winch bar in the future to accept the winch
Any advice would be appreciated from people who have either of the bumpers. TIA
Hey guys,
WInch bumper FTW...
+1 for the winch bumper. Like others have pointed out the weight savings between the two is basically nothing and if you decide you want to run the winch later it's already set up for it. Ran mine with no winch for years
Ok, got a question to the group and don't hate me for it. But I have been looking into V8 swap (6.2 LS with a 6i80e) my 1991 FJ80 that has stock 3FE.
I don't have the ability at my home or a buddy's shop to perform the swap myself, so that leads me to a shop performing the work. I live in the Dallas / Fort Worth area and the shops I have spoken to the price ranges from $30,000 - $50,000. Is this stupid to do as that price point? I can buy a new off-road rig and get more power and better performance.
The reason I'm looking at a V8 swap is more power and better gas mileage; my rig has a 2-inch lift and is running 33's, and no big / heavy bumpers front or back?
Thanks for any words of wisdom and insight you all can give.
