3FE fuel pressure guage install?
Pocatello, Idaho
I need to install a fuel pressure guage on my 3FE. Anyone installed a remote sender style on their 3FE? Any good suggestions on where to tie into the fuel injection. I have a cyberdyne digital one on my Mitsu but tying into the Toyota looks a bit more difficult. Any help would be appreciated.
No mechanicals, I'd prefer to keep the fuel in the engine bay. I haven't decided on a guage yet as I've been looking at some of the setups running around the board. One of those combo pyrometer, fuel pressure digital displays looks like the trick.
I'd like to use a remote sender with a electrical interface to the guage in the cab.
The cyberdyne one I'm using in my mitsu has a 1/8" NPT fitting. The large banjo on the fuel inlet and dampener looks like a pass, the banjo fittings on the cold start injector don't look to promising as does the banjo on the fuel pressure regulator. The only possibilities I see it to tap into the rail or to cut the cold start line.
I've wondered about this myself. The factory manual says to remove the cold start injector and use that port but I couldn't figure out a way to piggyback the banjo fitting either for a permanent guage install. I hadn't thought about just drilling and tapping the rail but that sounds reasonable.
Uh, yeah, and I need any info you'd be willing to spare on your turbo'd 3FE :) Is the engine stock? Specifically I'm wondering if you did anything to the bottom end to try and make it more reliable at higher output than stock but I'd also be interested in any fuel injection modifications that you did, turbo location and mounting and any other interesting details (and photos)...
When testing fuel pump pressure recently a friend loaned me his gauge that had a banjo connection that attached to the fuel filter outlet. That seemed like it could have been a permanent install location for a mechanical gauge set up or maybe as a place for an electrical sending unit.
I am wondering what the final outcome of this was?
I want to fit a permanent fuel pressure gauge in the engine bay.
I thought about doing it where the cold start injector ties into the rail, but I think those banjo fittings are too small. Russell sells a fuel pressure take-off banjo bolt, but the only size is M12...
Search: Adapter Fitting; Banjo Bolt; M12 x 1.25 in.; w/0.125 in. NPT Female Port
My 3FE is in a Pig now, and I spliced in a GM Vortec fuel filter as they came in much less expensive than the 3FE filter.
I am wondering if I cold get a fitting for the filter that would accomodate the fuel pressure gauge fitting as well?
Where do you all like to shop for fuel line fittings?
Bumping this thread to see if anyone has learned of any good installs?
I still like that Russell fuel pressure takeoff banjo bolt, but like I said, it is M12.
I believe the banjo bolt for the cold start injector is M8x1
Perhaps the banjo bolt at the fuel filter is M12x1.25, in which case you could mount the banjo bolt w/ fuel pressure gauge right at the fuel filter.
If the filter uses an M12 banjo fitting, I would guess that'd be the way to go. Be an easy install if that were the case, and I like the idea of monitoring fuel pressure too. Might be a great indicator of if/when your fuel pump is going out.
No totally sure, but I think Autometer's fuel pressure gauge kits come with an M12 banjo fitting adapter too.
